Message 11 of 14
Re: Bt tv remote not working at all, except to put box on and off
Did you factory reset your BT TV Pro box @mikeinlyme ? It sounds like it just needs to pair itself to your box again (the power button would continue to work even when not paired).
Press the Home and 9 buttons at the same time.
Hold down the buttons until the LED around the BT icon flashes purple three times.
Message 12 of 14
Thanks Darren, I think my box is Kaput as it gives no picture on TV.
One day all is OK and then nothing.
I held down 9 and home until 3 flashes, but nothing.
Woe is me.
Mike
Message 13 of 14
Hi Darren, the fault was that the HDMI socket on the TV that the bt box was plugged in to was faulty!
Very rare I am told, the TV is a Samsung smart tv and is less than 2 years old.
Now plugged into spare socket ( there are 4) and all OK.
Thanks for replying.
Mike
Message 14 of 14
Thanks for the update that may help others in future.
