Message 1 of 6
Bt with sky user - can’t watch footy on discovery plus
I’ve got bt sports through sky - now tnt sports
I can watch the football on my sky boxes but can’t stream via the discovery plus app. I registered via my sky q box as I should though when I try to open a tnt channel on the app it states ‘contact your provider to find out how to watch’
Please could you help asap - I watch the footy on my iPad regularly from hotels and am already missing games
5 REPLIES 5
Message 2 of 6
Re: Bt with sky user - can’t watch footy on discovery plus
According to sky community forum if you pay SKY for BT/TNT SPORTS  then currently you cannot access via discovery plus but SKY hope to make it available soon
Message 3 of 6
Ok cheers.
Checked sky forum, recent September posts saying this should be enabled now. Not for me. Have posted on there anyway to see if can help
Message 4 of 6
Hi @kennyboy993   If you pay Sky for TNT Sports then you can watch the channels on Sky Go.
Message 5 of 6
Thanks pal - literally just realised that a few mins after my post. I’m sure it wasn’t that way when before as I had to have Btsport app. Anyway that’s me sorted
Message 6 of 6
If you pay Sky, you use Sky's app and their process for activating discovery+
If you pay BT, you use BT's process for activating discovery+ (and previously had access to the BT Sport app).
No matter how you activate discovery+, all channels are available on all supported platforms now - including SkyQ.
