Message 1 of 6
Btp -15000
Been a BT/ EE TV subscriber for a while had the set up for over a year, recently moved house, when setting up the TV error code btp- 15000, box previously was connected via ethernet so reset to factory settings and wanted connect wirelessly but after initial set up was again met with the same Error code btp-15000.
Rang the helpline they were very lovely and friendly but unfortunately unable to solve the issue
Any help ?
5 REPLIES 5
Message 2 of 6
Re: Btp -15000
Which BT box/receiver are you using which displays this error code?
Message 3 of 6
Re: Btp -15000
BT TV Box Pro
Message 4 of 6
Re: Btp -15000
It's possibly because your BT TV service is still linked to the your old address.  Call 0330 1234 150 and press option 2.  Costomer Services should be able to sort it for you or transfer you to someone who can.
RIC9380
Message 5 of 6
Re: Btp -15000
If you've not got it sorted yet then you're welcome to email me at [email protected] and it should only take a minute to fix. Make sure you include your account number in the email.
Message 6 of 6
Re: Btp -15000
Perfect thanks guys, rang the number and like you said solved in a matter of minutes very impressed with the service.
Thank you for all your help
