Message 11 of 18
Re: Bug I haven't encountered exactly before, viewing experience ruined by it
Maybe I should ask them to swap the box to a newer model. I'll lose a lot of recordings, but it'll be worth it if I have no (or at least a lot less) recording failures and other issues.
Message 12 of 18
Hi @naylor2006
Thanks for coming to the community and reporting the problems you are having.
If you get in touch with our broadband tech guides and they will get your options looked into for you.
Let me know how you get on 🙂
Leanne.
Message 13 of 18
Hi @Leanne_T
I dont really have anything to report or take support on, I wasnt the OP, that was @MartinJSUK I was just sympathising as sometimes my box has the odd bug or issue, which I find 'acceptable'.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 14 of 18
Sorry about that, thanks for letting me know @naylor2006 🙂
@MartinJSUK if you give us a call the team will get this looked into for you.
Let us know how you get on 🙂
Leanne.
Message 15 of 18
Had an engineer visit just over a week ago, replaced the phone socket, seemed to be significant improvement to both internet speed and TV box reliability, but now had the same bug again, from Sky Sports F1 through Now TV. Ended up with another faulty recording (got 2 seconds of program before it cut out) as a result, now probably won't have time to watch it. I'll raise it with customer support.
Message 16 of 18
I had the exact same problem with the F2 sprint race earlier today, watching it now through the Now app on the TV Box Pro.
This has happened before on the Sky F1 channel.
Message 17 of 18
Funnily enough it was the Feature race that I had it happen for. They're sending a new Ethernet cable, which I hope but don't expect to resolve the problem. My internet connection is still very temperamental too, despite the new wall box, it's supposed to be 35Mps-ish but fairly simple webpages frequently fail to load correctly (including this one just now) when I'm watching an internet channel and recording another.
Message 18 of 18
I had a weird bug at the weekend when watching a recording of Soton vs United.....although the recording was complete it every now and then it would just end and say "The Recording has ended" on a completely purple background, however it was possible to re-load it from My TV and then skip past that point and carry on. Proper weird.
