Message 1 of 3
Can I retrieve Recordings deleted in error ?
Hi, I have just switched to BT so am still getting used to the YouView box, remote etc. I have managed to delete a recording in error, my fault by not paying enough attention... is there anyway of retrieving them ?
Keith
2 REPLIES 2
Message 2 of 3
Re: Can I retrieve Recordings deleted in error ?
Unfortunately not. You can turn on delete confirmation in the settings if you want to protect yourself in future.
If the recording is recent, it may still be available on catch up.
Message 3 of 3
Great.... not the answer I wanted Darren, but thank you all the same , Keith
