Message 1 of 4
Can I use my own e.g Humax set top box instead of supplied YouView box?
My BT TV YouView set top box needs upgrading. Without wanting to sign a new contract can I use a recently purchased Humax or similar set top box instead?
3 REPLIES 3
Message 2 of 4
Re: Can I use my own e.g Humax set top box instead of supplied YouView box?
@kevvjj
No if you want to receive BT Subscription channels.
Message 3 of 4
thank you
Message 4 of 4
As long as it's a YouView box, it WILL work.  It'll automatically pick up the BT branding and configuration as soon as it's connected to a BT Broadband line. Older boxes may have restricted features though.
You can see the current list of BT provided boxes here: https://www.bt.com/help/tv/learn-about-tv/bt-tv-boxes
Other boxes are available that will also work - post the model number here if you're unsure.
