Message 1 of 5
Can an old box be used just for Freeview.
Hi.
Bought a bt TV pro box.  I know have an older box which is surplus.
Is it possible to give the box if I wiped it to a family member who can use it as a Freeview box?
If I wipe the box will that mean that If the family  connected the box to the internet and went through the set up could they access my subscription channels as I don't want that to happen.
Thanks in advance
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Can an old box be used just for Freeview.
Yes, it can be used as a Freeview PVR.
No, they won't have access to your subscription channels.
Message 3 of 5
Thanks for the reply.
Just thought I'd ask as when I set up my pro box the subscription channels were already there without me doing anything. Am I right in thinking that's only because the box is connected to my router which tells it which package I have?
Anonymous
Not applicable
Message 4 of 5
The subscription channels are tied to your connection rather than the Hub.
Message 5 of 5
Thank you mate. Much appreciated
