Message 1 of 4
Can't record anymore
Hi, I recently noticed that things I had set up to record (Freeview channels), were not recorded. Also  now when I go into guide and try to record using the red record button on my handset it no longer works. I have tried restarting the box and retuning the channel but no change. Can anyone advise / help?
3 REPLIES 3
Message 2 of 4
Re: Can't record anymore
Next stage would be a maintenance  mode reset (keeping recordings).
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
However  it may ultimately  require a full reset which would lose you your current  recordings.
Are you able to view your existing  recordings  normally ? Also how much disk space do you currently  have available  ?
Message 3 of 4
I know absolutely nothing about BT boxes so this is just a guess. Is there a storage management setting on the box? if so then perhaps the disc is full and it is not set to overwrite the oldest recording?
Message 4 of 4
Thanks factory reset has worked
