Message 1 of 2
Can’t record
Recently bought a new Smart Tv. My remote control for my Youview box only switches the tv on but does nothing else.
I can’t record using my BT box any longer.
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Can’t record
Try Home+9 on the remote until it flashes, then Home+7. That should reset/repair the connection.
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
