Message 1 of 3
Cancellation of TV Package
Hi, I have just cancelled my BT TV Package, do I need to send my YouView box back to BT ?  I had had the package for a few years before cancelling.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Cancellation of TV Package
Hi.   I don’t think you need to return the box if you had it for a while. Can’t remember the dates for which you would have to return any equipment ( possibly if you joined after 19th December 2019).. But BT will send you a returns bag if you need to return it otherwise it’s yours.  Hope this helps.
Message 3 of 3
Thank you, I am thinking of not returning but I’m just a bit scared that they charge me if I don’t return.
