Message 1 of 3
Cancelling BT TV
Hi, I’ve been in contract for BT TV since Dec 20 and currently on BT Essentials (out of contract since Dec 22), if I cancel completely - will I be charged for return of the box? As it has currently failed and isn’t working anymore
2 REPLIES 2
Message 2 of 3
Re: Cancelling BT TV
If you get your Youview box or router after December 2019 then you will have to send it back.
Message 3 of 3
You will be required to return the box, but you won't be charged to return it (the postage is free).
