Anonymous
Not applicable
Message 1 of 3
Channel 5 app. 3 times
Just turned on my BT PRO box and the home screen is showing the apps. BBC  iPlayer, ITV X , 4. Then there is the 5  app showing three times. When highlighted they all show The Feud ...
So in total there are 6 tiles on the home screen.
2 REPLIES 2
Message 2 of 3
Re: Channel 5 app. 3 times
Perhaps something went a little of plan with a software update so my first thought would be seeing if a new software update would fix it, either that or a simple power off and on. Hopefully one of those will fix it.
Failing that it may need a factory reset, you can do one which will keep your recordings etc but may need the apps to be signed back in.
Anonymous
Not applicable
Message 3 of 3
@Manatarms84   Done software update but no update found. Back to home screen and that has fixed it. Now showing normal tiles..
