Message 11 of 14
Re: Channel 5 not recording
Hey there @phunt110.
Have you given the reset options I've mentioned earlier in the thread a try?
Also have you spoken with anyone in our technical team about this yet?
Peter
Message 12 of 14
Hi @Peter_W
I haven't done a reset yet as I don't want to losing any of my recordings.
I'd there a way of doing a reset without losing my recordings ?
Paul
Message 13 of 14
Hi @Peter_W
I have done a factory reset (keep recordings) and the issue has been resolved. I can now record programmes on channel 5.
Thank you Paul
Message 14 of 14
Hi @Dotty2025
My issue is now resolved. I did a factory reset(keep recordings) and the issue has been resolved. I can now record programmes on channel 5.
I have a BT Pro box and when you click on the Factory Reset option it will ask you if you want to keep your recordings.
Hope this helps ?
Paul
