Message 1 of 12
Connecting EE TV app to wired TV box
My BT/EE TV box is connected to the internet via wired ethernet because the WiFi signal is weak where the box is.
I have the EE TV app on my phone, which is connected to the box; I can set programmes to record and see recorded programmes.
I now want to connect a tablet to the box. When I try to connect the app to the box, it can't find it. It seems to only search on WiFi.
I don't remember how I connected my phone app to the box; it was a while ago. Do I have to connect the box to WiFi to connect the app and then switch it back to the wired connection?
Tags (2)
11 REPLIES 11
Message 2 of 12
Re: Connecting EE TV app to wired TV box
The EETV app, on iOS at least, uses broadcast to discover the box, it wouldnt matter if its wireless or wired, the only thing that matters is when you are trying to add a box to the app you need to be within the same network as it because broadcast wont find something on a different network.
So if you are connected to a wireless network serving a different subnet (ip range) than the box is on, it wont find it, say the iPad is connected to some different wireless network and the EETV box is not.
You just add the box via the app I think, in the settings bit then 'TV Box', the phone finds it then you have to approve via the box remote from memory.
Perhaps the limitation is how many apps can control the box, is it one? I dont know.
I did read over on EE that sometimes if you cant discover the box powering it off and on works....
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 3 of 12
You can have up to 4 devices registered on an account to allow a very limited number of channels to be watched via the EETV app. I think this includes the TNT Sports and Eurosport channels and Discovery channel and possibly the Asian channels?( I don’t subscribe to those though).
As far as being able to set recordings from the app is concerned, I wouldn’t be surprised that this is restricted to a single device, but I don’t know for sure. Almost unbelievably the email address that you used to be able to contact Mr Dev about tv apps on has been closed since he left the company!
Message 4 of 12
@DavidCheshire
If you want to pair the Box with your tablet, you will have to unpair it from the phone first.
The tablet, when you are looking to pair, is listening out for a Mr Humphreys-like “I’m free!” which will never come from an already-paired Box 😛
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 5 of 12
@Midnight_Voicewrote:
@DavidCheshire
There you go then, 1 device per box.
Message 6 of 12
OK, so I turned off all the notifications from the forums, but I can't help but pop my head in now and then to see what you guys are chatting about.
You can pair multiple devices with the same TV Box - I don't know if there's a limit (I've never hit one). The box runs a service that listens for broadcasts on the network from apps looking for it - this has been known to crash in the past. Try rebooting the box to see if that helps. If not, try rebooting the hub too (as it could be the broadcast not getting through - this has been known to happen on older hubs). If you're using powerline adapters to connect the ethernet, reboot those too.
If all else fails, a "factory reset, keep recordings" will reset the pairing service - you will then need to re-pair the box with the phone that's already paired though (as it'll be seen as a new device after the reset).
Message 7 of 12
That’s interesting. However, with our 2 Pro tv boxes I’ve got 1 paired with my phone and the other paired to my iPad so that I can easily remember which box is which. I don’t really want to keep an ear out for Mr Humphries, so I think that I’ll leave things be.
Message 8 of 12
Thanks, this was the clue I needed.
The box is wired via ethernet to the BT hub, but the tablet was connected to the house WiFi mesh network.
I connected the tablet to the BT hub WiFi and the app found the box and connected to it with no trouble.
Message 9 of 12
Ahh great.
Maybe turn off the WIFI on the hub and put the MESH WIFI within the same LAN as the hub, because you may find that when back on the MESH you wont be able to find the box again even though its added. Maybe its all on the same subnet already and the broadcast just wasnt making it through for a different reason.
I remembered this when you posted because my EETV is on a different LAN and I had to enable mDNS repeater to hand over broadcasts on one network to the other, although I doubt you can enable this on the hub.
Message 10 of 12
The mDNS is only used for pairing. Once paired, all EE TV app communication is via the cloud.
If you want to cast to the TV Box from Netflix or YouTube though ...
