Message 1 of 6
Control Onkyo Amp With EE remote
Can I control my Onkyo TX-L50 Amp with my EE TV remote
5 REPLIES 5
Message 2 of 6
Re: Control Onkyo Amp With EE remote
The BT/EE Pro Bluetooth remote won't be able to control your Onkyo amp directly. It is designed to duplicate some of the functions of a TV remote when paired with the TV, so if your TV remote can control your amp, the EE remote, when paired with the TV, should be able to do so as well.
Message 3 of 6
Hi Jones_01
Thank you for your reply. My tv remote does control the volume on my amp so can you advise how I replicate this?
Message 4 of 6
Your EE remote needs to be paired with your TV. Instructions how to do it are given here:
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
Make sure that both your Pro box and your TV are switched on and your TV is switched to the box's HDMI input.
Unfortunately, not all TVs are in the Pro remote's database.
Message 5 of 6
Thank you very much, I will try this tomorrow.
Message 6 of 6
Please report back on how you get on.
