Message 1 of 8
Disabling USB port when Pro box is in standby
Hey guys,
I am using a usb strip light to create illumination behind my TV. The USB port on my TV doesn't seem to have enough power output for the light but I have success with the usb port on the pro TV box.
However, the box continues to power the strip light even when it's standby.
Is there a way to adjust usb port settings, so it kills off the power and light when I turn off the TV box via remote?
I've had a mooch around the box settings and it doesn't seem possible. I'll check internally, but figured you guys might already know.
@zulu17 @Midnight_Voice
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Disabling USB port when Pro box is in standby
AFAIK, the USB port has no user functionality, it was only ever loosely defined as a service port. So I suspect the only way to kill it's output would be to alter the standby settings. But then you face waiting a fortnight for the thing to boot, even if that does work.
So you'll probably need to look to another device for power. Do you have a Bluray player with a USB?
Does the TV have a second USB? Sometimes one will have a higher current rating than the other. Or back in the days when USB powered HDDs first became a thing, they would often come with a double-headed cable for the same reason, lack of current from a single port. Maybe have a scout round for some sort of splitter.
Edit: they do exist!
Message 3 of 8
@NickBS
Given what the port is used for, accessibility features including keyboard for users who can’t use a remote, I would predict that it has to stay powered up so such users can power on the YouView box from standby.
Does your TV by any chance have a USB port with a blue divider in it? This would be a more powerful USB3 port that should do the job. The One Connect box for our kitchen/diner Samsung JS9000 has such a USB port, and I recall being disappointed I couldn’t charge my drone from it except when the TV was on, so it is definitely switched.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 4 of 8
I suspect that as the USB port is available to plug in an accessible keyboard/keypad for box control it remains powered in standby to allow a keyboard user to bring the box out of standby.
Anonymous
Not applicable
Message 5 of 8
I stand corrected on the keyboard function of the USB port!
Message 6 of 8
@NickBS
If the Pro box is like earlier Youview boxes, power to the USB socket goes off when the box goes into deep standby.
Anonymous
Not applicable
Message 7 of 8
@NickBS
If manual control is acceptable, then you could use a switch in the power cable.
I use something similar to this to control power a Bluetooth audio receiver that I don't want running continuously:
Try searching on a shopping site for "USB Switch Cable" or similar.
Message 8 of 8
I used a strip light when I had the Pro box. I adjusted the settings to deep sleep overnight and return to standby at midday. Worked perfectly for me, try selecting a time to suit your working day.
