Message 1 of 6
EE/ BT TV
I am unable to watch live tv, error code IPC6007 and also unable to watch recordings, error code IPC6029.
Tried rebooting and checking all software updates. Unable to check app updates due to error
thanks
5 REPLIES 5
Message 2 of 6
Re: EE/ BT TV
Message 3 of 6
Re: EE/ BT TV
Hi @Robertdonachie
the advice given at
https://www.bt.com/help/fix-your-bt-error-code-problem
is
if you still see the error message then try restarting your equipment by following these steps:
  • First, restart your Hub
  • Wait for the broadband light on your Hub to go blue
  • Restart your TV box, using the power switch on the back
  • Now check if you still receive the error
Message 4 of 6
Re: EE/ BT TV
I am on the BT chat but is taking forever 🙈
Message 5 of 6
Re: EE/ BT TV
Yeah I have tried this thanks but no joy 😩
Message 6 of 6
Re: EE/ BT TV
This has now been resolved via chat taking me finally through a soft factory reset to enable me to save all my recordings 👍🏻👍🏻
