Message 1 of 4
EE TV APP problem
Yet again, something that was working fine has been broken by an update. I had no issues with the app until I was recently forced to update and now it fails to show any new Scheduled recordings.
On Android 15, I've uninstalled, cleared the cache, re-signed in and the issue persists.
Also in the History section it used to show newly requested programmes at the top - some bright spark programmer has decided I now need to scroll to the bottom of the list to show the latest requested entries. This is only a minor point, but just another example of something that was fine and logical, instead of being left alone, being changed for the worse, for no apparent reason.
This is why I don't usually update apps until I'm forced to - the likelyhood of things breaking or getting worse seems so much higher than any improvements for the user.
3 REPLIES 3
Message 2 of 4
Re: EE TV APP problem
I hadn't noticed that the History listing had been reversed, but I see it now.  I don't have a problem seeing new scheduled programmes.
I have noticed that the scheduled programmes don't show a synopsis and it is random whether the delete button appears. I don't know if it is new but there is also a swipe left option to delete a programme, which only works if the delete button is there.
Message 3 of 4
Thanks. I've found the programmes not appearing in the Schedule on the app (but they do still show up on the ee box itself) are when recording multiple single episodes of the same programme on a channel (not using series record).
It will schedule whichever episode is requested first but the app now won't show any of the additional ones requested. I tried requesting the missing ones on the same but SD instead of the HD channel and again only the first one requested shows up on the app - all still show up on the ee box.
Swipe delete was there previously, but it's a bit different now that it's required to swipe then press to confirm.
Message 4 of 4
I didn't mention the other point mentioned above - confirming the programme synopsis for all scheduled recordings has disappeared since the app update.
