Message 1 of 5
EE TV Froze
Tv stuck Wecome to EE TV screen this morning, have rest box and internet a couple of times. Worked fine last night.  What do I do?
4 REPLIES 4
Message 3 of 5
Re: EE TV Froze
@Kdh7 Which box do you have?
What you are experiencing appears to suggest a problem with loading the system off the box's hard Drive.
Message 4 of 5
Re: EE TV Froze
Hopefully this has cleared up for you now @Kdh7 .I had a similar fault.I removed the Power cable from back of Youview Box,waited 1 minute and plugged it back in and the system restarted after which I found it was OK.Not sure if this is exactly same as resetting the Box normally but worth a try otherwise.
Message 5 of 5
Re: EE TV Froze
I’m out at the moment but will try this later. Thank you
