Message 1 of 4
EE TV - Max number per house
We have received 2 TV Mini boxes as part of our new EE Subscription. I can see you can purchase additional boxes on eBay etc. Does anyone know if you run can more than 2 Mini boxes plus the TV Box Pro in one household?
IT SUPPORT TECHNICIAN - Comptia A+ Certified, MTA Qualified and MTSC qualified
3 REPLIES 3
Message 2 of 4
Re: EE TV - Max number per house
As they are Youview boxes  they should all work  although EE TV will restrict their own services if you exceed the  contracted number of boxes .  So the EE TV app and the subscription EE TV channels and the EE TV supplied "freeview" IP delivered  channels would be limited to your contracted number of boxes. Currently I believe there is a too many boxes  message if you attempt to use  EE TV on a further box and if you opt to have your EE TV service enabled on that box then one of your current boxes will have the service disabled.
Message 3 of 4
Thanks - any ideas if you can flick between the boxes - I.E if we added a 3rd mini box in the playroom as long as there are never more than 3 boxes in use at once?
Message 4 of 4
Hi
Yes you can i do it all the time . I have 4 boxes
