Message 11 of 27
Re: EE tv IPC6023 message
Morning @Dang2
Thanks for coming to the community.
Could you try these steps to see if this helps;
  • Restart your Hub
  • Wait for the broadband light on your Hub to go blue
  • Restart your TV box, using the power switch on the back
If you still have this error message, could you check your software version is up to date. To do this, press the Home (or YouView) button, then go to Settings, Software Information, Update Software and press OK.
Let me know how you get on 🙂
Leanne
Message 12 of 27
Thank you for your reply I've checked all this and still having issues.
Message 13 of 27
Thanks for trying  these for me @Dang2
In this case, please get in touch with our broadband tech team and they will get the error message looked into for you.
Leanne.
Message 14 of 27
Hi @Dang2 , as you might be aware IPC6023 dialogs are generally due to a lack of multicast or subscription eligibility failures.
Could you drop me a DM with your TV Box serial number so I can take a quick look at your broadband connection and account details?
thanks
David
Message 15 of 27
I will do when I'm home from work thank you 🙂
Message 16 of 27
Also how do I direct Message, sorry to ask
Message 17 of 27
No worries, if you click on my name, there's a view profile option where you'll find the "message" button.
Message 18 of 27
Hmm there doesn't seem to be an option to message,
My box serial number is : Serial No.:+097445+2321005067
Thank you for checking for me
Message 19 of 27
@Dang2
Do you not see this, with the purple ‘Message’ box?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 20 of 27
I don't? Maybe because I'm using a mobile?
