Message 1 of 4
EE update issue
Following an EE software update this morning, my BT box does not show and programme content, tv guide show programme list but selecting anything results in blank screen.
loading any app from the menu results in a loading screen,then have to restart the box
My tv box is model RTIW387
any thoughts appreciated
thanks
3 REPLIES 3
Message 2 of 4
Re: EE update issue
Hi @davef2
I believe that is the TV Box Pro,
If none of the restarts/poweroff/poweron  devices  cures the issue then you have the choice of contacting BT (or EE if your contract is with them) or attempting a reset of the box yourself
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
there are reset  options to preserve recordings.
Message 3 of 4
Re: EE update issue
thanks zulu17
I managed eventually to reset and get ee to update again. following a correct restart everything is now working.
Message 4 of 4
Re: EE update issue
Any idea what the update was for?
I am down as tester and I haven't had it yet.
I wish they would give a one liner on what these are for.
