Message 1 of 15
EETV or Sky Q
I am thinking about moving to EETV with the Entertainment package with HD boost and duo mini tv boxes. At present I have been with Sky for over 26 years. Can’t justify sky increased prices in April will cost £58 per month. The EE TV package is £36 per month.
what is EETV like and help / guidance would be appreciated
14 REPLIES 14
Message 2 of 15
Re: EETV or Sky Q
@Partykiosk Ask plenty of questions and don’t assume that everything works in the same way that you’re used to with Sky. It doesn’t. If you tell us what’s important to you, we’ll let you know if you you can expect to get that with EETV. Plenty have come unstuck when it comes to multi-room and recordings and mini boxes, for example.
Message 3 of 15
Re: EETV or Sky Q
I know that you can’t watch recordings on the mini tv boxes, but what is NOW like and what is the picture quality like and the EPG tv guide like
Message 4 of 15
Re: EETV or Sky Q
Have you thought about maybe going with Now direct. They often have discounts that EETV dont offer.
I have Now direct since leaving BT TV as it was called and picture quality is very good when watching HD.
I Have entertainment , Sky Cinema and Boost.
EPG on EETV is fine. It can go back 7 days or forward 7 days.
You will also find that the box dont have all the same apps that you get with Sky Q. If you go for the pro box.
The EPG via the Now app just has a now and next.
The Now app is due to get a new look with a software update in the coming weeks.
Message 5 of 15
Re: EETV or Sky Q
Thanks ney,
I presume you can watch live BBC and ITV channels on the pro box and not through BBC Iplayer or ITVX apps.
The wife wants the pro box so she can record programmes.
Message 6 of 15
Re: EETV or Sky Q
Ok this is where it may get a bit sticky. You can watch the terrestrial channels in two ways, via IPTV (broadband, no need for a aerial) or over the air which needs an aerial (you can't use a satellite dish).
Via IPTV there are less channels, and you can't record the BBC channels (you can set a timer to "record", but when it comes to playing it back it opens iplayer to view. And recording from the ITV channels you can't skip the ads. All other IP channels are recordable though.
Via the aerial there are no restrictions, but again you can't use your dish.
Message 7 of 15
Re: EETV or Sky Q
But I presume that you can’t use both (Iptv & aerial) the same time? It will have to one connection
Message 8 of 15
Re: EETV or Sky Q
@Partykiosk
Per device yes, you have to set the Box Pro up in either Aerial Mode or IP Mode.
If you change your mind, you can swap, but it needs a Factory Reset as part of this, so it’s best to get it settled before you start.
The Box Minis are only ever in IP Mode.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 9 of 15
Re: EETV or Sky Q
@Partykiosk If recording is important to you it might be worth bearing in mind that IP only allows 2 simultaneous recordings. Aerial mode allows for 4 terrestrial channels as a minimum and 2 IP channels simultaneously. It’s also a question of quality v quantity as far as PQ is concerned. You get more channels in aerial mode but more HD channels in IP mode.
Message 10 of 15
Re: EETV or Sky Q
It's a crying shame that the IP channels haven't increased in content in the last 2 years or so. The crazy thing is Freely have more free streaming HD channels than EETV. Even Legend, PBS America and True Crime is vastly superior, quality wise, to their EETV equivalents.
