Message 1 of 4
EETV over WiFi distance from router
Hi
I am thinking over switching over from sky to BT with TV package.
I am however concerned that it is recommended that the pro box needs to be within 5 Metres and currently my hub is probably half a metre to a metre over that. Their is a Line of sight from the box to router and have had no problem streaming with my firestick or sky box.
Do you think eetv would be compatible with current network layout?
PS- would rather not run cables if I can Avioid it.
Thanks!
3 REPLIES 3
Message 2 of 4
Re: EETV over WiFi distance from router
With clear line of sight, it's not likely to make one jot of difference.
Message 3 of 4
Hi
Yeah I mean their is a strong signal between 3 and 2 bars so I'd say thats good enough?
Anonymous
Not applicable
Message 4 of 4
I wouldn’t worry the pro box works perfectly over wifi.
