Message 1 of 7
EETV v BTtv - Box Pro differences - are there any?
I'm a BT customer and as a part of my long running broadband issues I've had the BT Box Pro replaced by the EE branded Box Pro.
They are slightly different sizes and carry different branding - but are there actually any techinical differences?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: EETV v BTtv - Box Pro differences - are there any?
When New EE launched @DarrenDev confirmed it was the same hardware in a new frock.
Message 3 of 7
@ozsat  When you go into Settings  Device Information on your box what does it show as the Variant of your box ?
Message 4 of 7
There is a new Bluetooth remote which has less buttons than the old remote. Some buttons have two functions, such as the Record button which can also be used to delete a recording.
The old infrared remote still works on the new box which is useful if you have one and are used to the layout (and extra buttons).
Richard
Anonymous
Not applicable
Message 5 of 7
@barnpiecewrote:
There is a new Bluetooth remote...
Both boxes use the same bluetooth remote.
Message 6 of 7
It say RTIW387.002.P
Message 7 of 7
The remote I got is the same as the old one except the BT button now says EE
Richard
