Message 1 of 5
Entertainment package rules
Just temporarily  (probably) switched  from Sport to Entertainment package.
Can anyone give a simple explanation of how many users are allowed for Netflix and Now TV, both at the same time and whether there are any rules such as waiting for 30 days to nominate a new device etc etc.
4 REPLIES 4
Message 2 of 5
Re: Entertainment package rules
I know you asked for a simple explanation but I thought it best to give you a couple of links to show how Netflix and Now describe it,
With the Entertainment  it is  the  Netflix Basic pack that is included .
https://help.netflix.com/en/node/2492
“Watch  NETFLIX on 1 supported device at a time”
For NOW
https://help.nowtv.com/article/managing-my-devices#:~:text=Watch%20on%201%20device%20at,streaming%20...
“If you're a BT customer, you can watch NOW on 2 devices at once as long as one is a BT TV Box and you start streaming in the correct order.“
If these are not sufficient you can pay for  an addon to your BT TV pack for NETFLIX Standard or Premium .
For NOW there is NOW Boost addon available  to increase the number of streams that may be available as a separate addon to your BT TV pack or it may be included when/if you take the BT TV HD addon.
with both you should be able to stop watching on one device and start watching on a different device straightaway  providing you have closed the stream correctly.
Message 3 of 5
Hi @homerhotspur
For Netflix:
  • A Netflix Basic plan, watch unlimited movies and TV shows on 1 screen at a time in HD.
  • A Netflix Standard plan, watch unlimited movies and TV shows on 2 screens at the same time in Full HD for those in your household.
  • A Netflix Premium plan, watch unlimited movies and TV shows on four screens at the same time in 4K Ultra HD for those in your household. Subject to your internet service and device capabilities.
https://www.bt.com/help/tv/learn-about-tv/channels-and-packages/netflix-from-bt#:~:text=A%20Netflix%....
For NowTv:
BT customers can watch on 2 devices at once (as long as one is a BT TV Box and you start streaming in the correct order), or 3 if you have NOW Boost. If you're watching on a BT TV Box, to watch on 2 devices at once you'll need to leave the NOW channels and start watching on the NOW app.
https://help.nowtv.com/article/bt-support#
I’ve signed in on multiple devices (phones, tablets, Apple TV, Roku, fire stick etc) and not been hit with a device limit, so not sure they are enforced any more. It’s just limited by the number of concurrent devices and ‘household’ as per the new Netflix rules.
Hope this helps
MikeAlanR
Message 4 of 5
For NowTv:
So, for Now tv, if 2 devices at once required, you have to use the NOW TV app on the box menu rather than the individual channels from the guide ( which I have only just discovered were a thing) . Is this also what is meant by ' streaming in the correct order' though , as it doesn't appear to be an order related thing more an access related thing?
Message 5 of 5
If you are already  using the Now app on another device then you can start watching the Now TV as live TV  on your BT TV box  (the ones in the box EPG ).
If you are already watching a Now TV channel on your BT TV box . Then if you use another device  to run the Now App it will recognise  that your Now membership is already in use.
