Message 21 of 31
Re: Error code YVM607
Thanks for the tip. I may try that in the future, at the moment I feel I have wasted enough time on the issue.  I have now come to a workable solution in as much as everything works properly if I just confine myself to SD channels, which are the majority anyway. I just don't use chanels 101HD, 102, 103 etc. Just watch on 1,2 or 3. I have enhanced my picture as much as possible and as it is only a 32" screen it is perfectly watchable. Thanks for all your help.
Message 22 of 31
After messing around with this intermittent fault for the last 6 months, doing all of the fixes, buying new cables etc etc. I even contacted Samsung and had them remotely access and check TV. Finally I went through to BT tech support on chat. Apparently the fault was with the broadband box and the sync.
they are calling me back in a week to see if it’s still good - I have everything crossed!
Message 23 of 31
The error code I only get with TNT sports Ultimate, all other channels are OK. We had the older BT box and never had a problem until we upgraded to BT Box Pro. I think I have tried proposed solutions but it's still a problem. Annoying as we aren't getting something we pay for. It's a Samsung TV
Message 24 of 31
I get this error message all the time. Box is only 12 months old.
Message 25 of 31
Ours was new only 8 months ago. BT really should consider a recall and replace these faulty boxes, it's atrocious, for what we pay.
We turn on our BT Box every day and then have to turn the TV off at the mains a d back on again, every day. Sometimes more than once a day.
Message 26 of 31
Agree. Same here. I've done all the suggested "fixes" and still it happens.
What's the best way of raising a complaint with BT? And will they do anything?
Message 27 of 31
Maybe some kind of online petition on a petition site and post the link here, and everywhere. Shame BT into action.
Message 28 of 31
I had this problem, when I connected my new BT Pro box into my old JVC tv (single HDMI port).  After searching Google, came across a suggested solution, namely to insert an HDMI splitter (it splits the incoming HDMI signal into two for two screens) between your HDMI cable and the TV port.  I bought their suggested one, eSynic 4K/30HZ HDMI Splitter, from Amazon, costing £11.  Linking one of the outgoing ports to the tv, it has been 100% successful for over a week now.
The reason appears to be that the eSync incoming port HDCP conforms suitably with the BT box; the outgoing ports do not seek HDCP conformity.
Note that you need an additional short  HDMI cable, which does not come with the order
Message 29 of 31
Hi @Kimbals  - please can I ask if you are you still experiencing YVM607 errors, if so, please can you share the serial number of your device please?
Message 30 of 31
Gavin, I've still had no further YVM607 errors.  Solution remains 100% successful
