Message 1 of 4
Extra remote for BT pro box
Is it possible to pair another BT Bluetooth remote to the pro box or is it limited to one? I did look online and saw someone suggest that the older model of BT remotes could be added but would prefer to stick with the newer version if at all possible.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Extra remote for BT pro box
No, you can't pair two BT remotes.
Message 3 of 4
The previous generation BT/Humax Youview remotes will work in line of sight to control the box by Ir signals. Useful if you already have one but i personally wouldn't bother to buy one specifically for that purpose.
Message 4 of 4
Yes you can have more then 1 Bluetooth remote for a bt pro box,I have 3 as we have our box connected to 2 extra tvs via a hdmi splitter
