Message 1 of 2
Fast forward banner staying on
When fast forwarding a tnt sports recording to say 30min and then selecting play, the bottom status banner stays on. This happens about 50% of the time. Other times it turns off after about 10mins.  How can I remove it?
1 REPLY 1
Message 2 of 2
Re: Fast forward banner staying on
Good morning @johnpcook, thanks for bringing this to our attention 😊
Have you had a chance to check if any other apps or streaming services to see if this issue occurs with those?
If you haven't already it's worth doing a reset on your box using the buttons on the front.
Unlike when you do a factory reset via the menus, this won't typically affect your saved settings and recording.
Peter
