Message 1 of 4
Getting tv package on a second tv
Can anyone advise how I get BT TV on a second tv in my house
3 REPLIES 3
Message 2 of 4
Re: Getting tv package on a second tv
There’s the option of an extra box subscription from BT for £10pm. However, you can only have one recordable box with your subscription which means that your extra box will be the non-recordable edge/mini box. It allows you to watch all of your subscription channels and apps the same as your main box but it does not record, nor does it allow you to watch any  recordings from your main recordable box.
An alternative is to watch via apps such as the NOW and HBO Max apps on a device such as a ROKU or Fire tv device which you would need to purchase yourself. Most but not all of the content on EETV is available on catch up depending upon which particular subscription package you have. Live content is also available on apps but there will be a small delay with these as the EPG channels are delivered via multicast.
Message 3 of 4
Thanks very much for your answer
Message 4 of 4
