Message 1 of 10
HD Channels
I am disappointed with the range of HD channels via BT/EE. Why is there no ITV4 HD for example? Or the other channel 4 channels.
 Can anyone advise? Is there any plan for BT/EE to add more HD channels?
9 REPLIES 9
Message 2 of 10
Re: HD Channels
Freeview is limited to the amount of HD channels it can offer due to the way it is set up.
If you have a Pro box and take out the areial you can reset it in Internet mode and you will get more in HD but less choice of channels, but hopefully BT/EE will add more in future.
Current list of channels in BT/EE mode are below:
https://www.bt.com/help/tv/guide/ip-freeview-guide
Message 3 of 10
Re: HD Channels
@medino they're all available in IP mode
Message 4 of 10
Re: HD Channels
All the ITV and channel four channels are in HD.
But they aren't all there. Some channels are missing altogether, but could be available if BT/EE could ever reach agreement with their suppliers.
Message 5 of 10
Re: HD Channels
Wow, ok.. that wasn’t in the setup guide. I will do that.
Presumable those channels are recordable as well? E.g. Tour de France highlights on itv 4 in HD?
Message 6 of 10
Re: HD Channels
They are recordable on the Pro box but you can't skip the adverts
Message 7 of 10
Re: HD Channels
I suspect @Weerab1983  may have confused channel 4 family of channels with channel 5 in the earlier reply on available HD channels on the Box Pro in IP mode.
 Several of the channel 4 family of channels are not in HD  eg  E4, Film 4 , More 4 , 4 Extra are not in HD on the linear channels on the Box Pro.
Message 8 of 10
Re: HD Channels
Do I have to do a factory reset to switch to IP mode to get the extra channels in HD?
Message 9 of 10
Re: HD Channels
I think I was. I wasn't at home at the time so couldn't check
Message 10 of 10
Re: HD Channels
@medino yes you have to do a factory reset with the arieal unplugged
