Message 11 of 19
Re: Hdmi output
I found it a bit cheaper on ebay,  anyway its ordered
Message 12 of 19
Re: Hdmi output
No good for me, it works with box but I needed a splitter that allows me to have 3 devices attached to splitter so I can swap between them when needed.
thanks anyways.
Message 13 of 19
Re: Hdmi output
You don't need a splitter. You need a switch.
Message 14 of 19
Re: Hdmi output
Ahh, ok,  you know one that works with a pro box? The one I have doesn’t and when I Google it splitters come up.
Message 15 of 19
Re: Hdmi output
This is 3 in 1 out. Works for me. Take care with hdmi cec where hdmi switches can override the switch. Also I don't have a sound bar. These seem to be tricky with switches.
HDMI Switch 4K, 3-Port HDMI Switch Splitter with High-Speed HDMI Cable, HDMI Switch 3 In 1 Out Supports 4K 3D 1080P UHD HDCP 2.2 for Xbox PS3/4/5 Sky Box Apple TV Fire Stick
Message 16 of 19
Re: Hdmi output
Thanks, that works great…..
Message 17 of 19
Re: Hdmi output
Does the 3 in 1 out aslo work as a 1 in to 3 out switch?
Message 18 of 19
Re: Hdmi output
It’s for 3 devices in to 1 tv, I have a switch, fire stick and my bt pro box connected so I do not have to keep swapping hdmi leads in back on tv.
Hope that helps.
Message 19 of 19
Re: Hdmi output
Well tried splitters and switches last one being ezcoo at £29.99 but all to no success,  never got bt box pro to connect to my old dvd recorder/player so have to admit defeat.
