Message 1 of 3
Hidden BT box
  • Are there any gadgets i can use that mean i can change the tv without the remote being able to aim at the box, i have hidden the box in a tv frane and now cant change channel. Can it be done through wifi?
2 REPLIES 2
Message 2 of 3
Re: Hidden BT box
What you are after is an "IR repeater" - available from all good online stores 😉  They do work - most of the time!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Anonymous
Not applicable
Message 3 of 3
Re: Hidden BT box
Assuming that you have a BT/EE TV subscription, see if you can persuade them to provide you with the latest Pro Box. The remote for that operates on bluetooth.
Hope you've made provision for good ventilation or it will likely cook itself.
