Message 1 of 2
Hidden channels
I notice that hidden channels on EETV/YouView are impacted when the channel numbers are changed.  So for example a channel that I had  previously hidden  which has been moved to a different channel number is now visible (ie unhidden).
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Hidden channels
I believe this has always been the case - it seems to hide based on the channel number rather than the ID, so if another channel has moved into the old position then that'll be hidden instead.
