Message 1 of 2
Hide or remove on demand apps
Hello,
Is it possible to hide or remove on demand apps?
My son has recently located the CBS/Horror Bites app and now has access to 18 restricted movies which is not ideal.
I have parental controls set up but it doesn't prompt for my passcode when selecting a movie.
Any help would be great.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Hide or remove on demand apps
It's not possible to hide them unfortunately and that app is common across all Freeview Play, Freesat and Youview boxes. I'd check the app itself or reach out to Horror Channel to see if a PIN can be added to block adult rated content.
