Message 1 of 6
How can I get a replacement FOC remote control?
I still have the original remote control from 9 years ago when I first contracted to BT.  The rewind button has not worked for ages and I can't see anywhere on the BT site where I can swap for a new one?
5 REPLIES 5
Message 2 of 6
Re: How can I get a replacement FOC remote control?
Hi @Canuck  do you have a current BT TV contract ?
Message 3 of 6
Yes I do.
Anonymous
Not applicable
Message 4 of 6
Then contact BT and they will send you a replacement. Dial 150 from your home phone or 0800 800 150.
If your box is as old as your remote, you may want to consider re-contracting and getting the latest hardware.
Message 5 of 6
Thank you.  Is there an email address you would recommend to contact them for the replacement controller?
Anonymous
Not applicable
Message 6 of 6
No email address, but you can do a live chat here:https://www.bt.com/help/contact-bt/technical-support/tv
