Message 1 of 6
How to stop live tv pause.
As there is no stop button on the pro TV box remote how do I go back to where the program would be live after pausing without having to fast forward all the way to catch up?
5 REPLIES 5
Message 2 of 6
Re: How to stop live tv pause.
I normally only pause live TV for short periods but when I want to resume live, I either fast forward or change channels and go back to the one I was watching
Message 3 of 6
Oh if you didn't know, you can hold fast forward to jump in chunks
Message 4 of 6
Yes I found that earlier when trying to work out how to do it. Seems silly there isn't just a stop button like on the old remotes.
Message 5 of 6
There's a few buttons missing that would have been handy but once you get used to it's quirks, it's fine
Message 6 of 6
@NigelB72
To resume 'Live' TV from a pause, you can press the up channel followed by the down channel buttons on the F1 remote, or if you have an old remote from a G4/G5 STB the white square button (next to the record button) does work.
