Message 1 of 2
I can't find any HD channels after scan!!DTRT2100
Morning all
We factory reset our DTR-T2100 BT youview box everything scanned back in but I can't find any HD channels anywhere.
We normally watch bbc1hd etc but only SD ones are showing.
I check signal strength and quality
Strength is 85%
Quality 100%
Any ideas many thanks Simon
1 REPLY 1
Message 2 of 2
Re: I can't find any HD channels after scan!!DTRT2100
@Gibbo1471
Last time I looked, there was a bug in the tuning process which means it doesn’t show any progress. So you have to let it run blind, until after about three minutes or so, it finally comes back with your location choices, if any.
Did you give it that long?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
