Message 1 of 4
I did a factory reset on my BT tv box but now can't get past start page, button doesn't work.
3 REPLIES 3
Message 2 of 4
Re: I did a factory reset on my BT tv box but now can't get past start page, button doesn't work.
Hi @Dottyaboutdals
Suspect that your remote has lost it pairing to the TV Box Pro when you did the factory reset.
see
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
Message 3 of 4
Hiya, I've already re-paired the remote but still can't move on from the start page
Message 4 of 4
Hi @Dottyaboutdals  - as already suggested this does sound like a remote pairing issue, I'm not aware of any other current issues that would cause this.
Have you tried both the key sequences in the linked instructions and/or changing the batteries in the remote control?
Gavin
