Message 1 of 19
I don’t have ITVX showing on my box
I do not subscribe to BT but purchased a BT You view box (from Amazon) purely to have HD, catch up etc.
My box has not updated to ITV X, do I need to purchase a new box? Is my tv too old.. not sure
Any advice would be welcomed
18 REPLIES 18
Message 2 of 19
Re: I don’t have ITVX showing on my box
Last time I checked on my BT Box it said 'ITV Hub' but loaded 'ITVX' - although not the FAST channel version.
Message 3 of 19
Compatible YouView/Freeview play boxes/TVs don't have the FAST channels apart from Samsung/LG smart TVs.
If your box isn't the BT TV Pro/BT mini box you will not get any version of the ITVx player due to age of devices/compatibility.
If your box is perfectly fine otherwise I would recommend buying a Roku player that plugs into your TV and gives you all the latest apps plus some other TV shows/films for free.
Its quite straight forward to use as well and you can get it off Amazon. Costs about £30
Message 4 of 19
Is ITVX considered a FAST channel never heard that before? Does the Roku player run alongside the current BT box or just plugs into one of the HMDI ports ? Thanks again
Message 5 of 19
Is that different from the BT TV Box Pro? I have one and there is no ITVX App that I can find. Tracking down anything on ITVX is a pain.
Message 6 of 19
@michaelkenward click on the itv app and itvx player will launch on the BT TV Pro
Message 7 of 19
@PAULINELYNAM FAST channels are channels under the live part of ITVx player that has exclusive free themed channels.
Roku/fire sticks plug into a spare HDMI port on your TV
Message 8 of 19
There is no ITV app that I can see. Never has been. Hence the question.
Message 9 of 19
@michaelkenward I don't know why you don't have the itv app on your TV Pro box.
I take it that it is connected to the internet and you have updated your software and apps.
If so, have you raised this issue before?
Message 10 of 19
No unfortunately this doesn’t happen. I don’t subscribe to BT . Box bought independently just for catch up & apps. It’s a YOUVIEW box . TV is is Panasonic circa 2015?
