Message 1 of 4
IP tv EPG issues
Channel 68 is showing the horrorxtra channel schedule on the EPG in IP mode but when you click on it  you get realityxtra.
I wonder when this will be fixed or they get a deal with CBS/AMC for an additional channel with the same supplier.
3 REPLIES 3
Message 2 of 4
Re: IP tv EPG issues
I think channel 68 on Freeview is currently broadcasting HorrorExtra with 69  being used for Realityxtra. So I suspect the equivalent of Freeview [free to air) guide information for channel 68  (ie HorrorExtra) is being provided to BT TV currently but BT TV is broadcasting the Rellityextra programming stream  that it is still receiving,
So yes the BT TV EPG data for channel 68 is incorrect in ipTV mode currently.
Message 3 of 4
Looking at the backwards EPG it looks like the issue dates back to Thursday 21st at 8am.
Message 4 of 4
There was a Freeview change in Wednesday when realityxtra and horrorxtra switched channel numbers
Hopefully BT update the channels soon.
I will keep this as not accepted until they do.
