Message 1 of 3
IPC6023 on live channels
using broadband connection and all good for last year or so.
All apps working ok but same message on all live channels telling me there’s a problem with broadband and quoting IPC6023.
I’ve rebooted and restarted the router and box several times.
box says good internet connection
I’ve got a hardwired broadband so speed is super fast
any thoughts?
2 REPLIES 2
Message 2 of 3
Re: IPC6023 on live channels
You'll need to raise it as a fault - there are many possible causes that can't be diagnosed without specialists looking at your line.
www.bt.com/contactus
Message 3 of 3
Thank you, will do
