Message 11 of 39
Re: IPC6023
Spoke to soon, 45 minutes into working, blank screen and back to the IPC6023 message 😭
Anonymous
Not applicable
Message 12 of 39
Re: IPC6023
@DarrenDev
Did you ever make the return to the fold & can offer any assistance?
Message 13 of 39
Re: IPC6023
I'm back, but have to pick my battles I'm afraid @Anonymous - I can't get involved in issues like this anymore, as they require complex analysis that I'm not capable of. Ultimately the fault will end up with the same team for resolution whether I get involved or not, and I don't have the bandwidth to act as middle man.
The only advice I can give is to call the helpdesk again and ask for it to be raised as a fault for TMC to investigate - though this should be the normal course of action on calling back with the same issue anyway.
Message 14 of 39
Re: IPC6023
Thanks for the advice
Been onto the TV team for an hour but no resolution. They seem to feel that my network switch TP-Link TL-SG105E is the issue, though it is a managed switch with IGMP Snooping so should be no issue (was fine with the BT Hub 2 and also the TV Box Pro and Mini do not work over WiFi either)
They are sending powerline adapters to try though I don't hold out much hope as connecting the Pro TV box direct to the hub via Cat8 doesn't work either.
Anonymous
Not applicable
Message 15 of 39
Re: IPC6023
@DarrenDev
Must be frustrating but thanks for the update.
Message 16 of 39
Re: IPC6023
Thanks @Anonymous
Had an update that they believe there is an issue with a small number of EE hub pro's that is causing the problem but they need time to narrow down the issue.
Will have to wait and see what happens.
Message 17 of 39
Re: IPC6023
Nearly a month in and no progress. Still getting the IPC6023 error. 😢
Message 18 of 39
Re: IPC6023
Sorry @Sirus_Monk - this is taking too long.  I've asked an expert to intervene and find exactly what's going on.
Message 19 of 39
Re: IPC6023
Thank you @DarrenDev
Message 20 of 39
Re: IPC6023
This whole move to EE has now become a nightmare, second bill due, still no TV with the IPC6023 error ongoing.
Now devices, either wired or WiFi connected stay happily connected to the hub but lose Internet connection intermittently for anywhere up to a few minutes.
Finally, can't check status of anything because the EE app refuses to connect to the hub. Even uninstalled it, reinstalled, connected OK. 20 minutes later, wouldn't connect again.
