Message 1 of 2
Issues with fast-forwarding and rewinding
I started watching my recording of tonight's Basel v Aston Villa match at about 9.30pm, but accidentally stumbled across the result while browsing the web at the same time (after the recording had finished), so decided to skim through it to just see any further goals before bed. The button to skip 60 seconds was skipping me anywhere from about 3-8 seconds each time, and when I saw that a goal had happened and attempted to rewind, the box started fast-forwarding instead. This is a persistent issue, which seems to affect all channels, but it's especially troublesome with live sport (the design of the fast-forward mode blacking out much of the screen, when TNT put the score in that area, exacerbates the issue). I can see that its a problem others have had. Are there any fixes?
1 REPLY 1
Message 2 of 2
Re: Issues with fast-forwarding and rewinding
I would check via the box settings that the software is up to date by going into the software option at the bottom of the settings and go to update on the right handside.  Failing that I would suggest a factory reset of the tv box (Whilst this will delete any recordings and sign out of apps etc) it will fix most issues with recordings, playback etc.  The option for this is also in the settings at the bottom
