Message 11 of 26
Re: Itv programs
We have registered and signed in and still can't get straight itv programs
Message 12 of 26
Re: Itv programs
There is no live icon on the left
Message 13 of 26
Re: Itv programs
Will try tomorrow it is giving me a headache I am useally quite good at sorting this sort of thing out but this really doing my patience.
Thanks for your info
Message 14 of 26
Re: Itv programs
@57mo  Have a good nights sleep.
Worst Case scenario you may have to factory reset your box and go the full setup process again
https://www.bt.com/help/tv/set-up-bt-tv/tv-box-pro/wi-fi
step 7 there covers pairing the ITV X app.
Message 15 of 26
Re: Itv programs
Can you confirm that I have correctly understood message 5, either you don't have an aerial connected to the BT Pro box or you are not using it.
Part of the setup procedure for this box requires you to login to ITX in order to that the app may acquire your location and show you programmes from the correct region, it may be that you need to do a factory reset and go through the setup process again making sure that you enter valid login details for ITVX when asked to do so
Message 16 of 26
Re: Itv programs
@57mo
To get the fully ITVX and in HD you are best getting the likes of an Amazon Firestick to use alongside your Pro Box.
I dont have the pro box but have the older version of the BT Youview Box and now hardy use any of the apps on the BT Youview Box and mostly use the Amazon Firestick for all the apps.
Message 17 of 26
Re: Itv programs
Yes we have an aerial into the box. We have done all the registering and signing in and still can't just get simpleold ITV programs without ITV X telling us to sign in
Message 18 of 26
Re: Itv programs
I have paired so may have to do as you suggest and do a factory reset.
Message 19 of 26
Re: Itv programs
Sorted it thanks
Message 20 of 26
Re: Itv programs
Something isn't quite lining up here @57mo - you say you have the aerial connected, but then you have ITV HD at position 3 in the TV Guide. I'm guessing the aerial wasn't connected when the box was first set up, as the box has gone into IP mode.
If you're happy with your TV aerial then I recommend you factory reset with the aerial still connected - this will force it to use the aerial. You then won't have this issue anymore.
If you want to use IP mode then that's also OK - just make sure you follow the ITVX sign in during setup, to enable the ITV IP channel.
