Message 1 of 5
Latest software adds recording from buffer and enables find my remote
4 REPLIES 4
Message 2 of 5
Re: Latest software adds recording from buffer and enables find my remote
It would be helpful if guidance as to how to record from the buffer were given.
Message 3 of 5
I think if you sit on a channel, long enough to have a buffer, simply press record and it will record from the beginning of the buffer.
Message 4 of 5
Buffers will commence once you tune into the current channel  ( possibly including previous programmes as well as current live). You have options to pause and  move back in the buffer. I presumed that the recording will be made from the point in the buffer that you are at when you start the record or is it intelligent enough to record the programme from its start time within the buffer. Can I record the previous  programme if it is still within the buffer. Some guidance would be helpful otherwise this feature is likely to go underused.
Message 5 of 5
 @JordanTA  It would be helpful if guidance as to how to record on EE TV  from the buffer were given.
