Message 1 of 3
Lost All Freeview Channels from 4K box
Hi All,
Hope someone can help me with this problem.
My 4k box, which I have had for a few years now, has suddenly lost all the Freeview channels. I have rebooted it without success, and also rebooted the hub. Freeview works fine through the TV so the aerial must be OK. I connected up to my old YouView box and freeview channels are there, so it looks as though my 4K box has developed a fault.
Is there anything else I can try before ringing BT?
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Lost All Freeview Channels from 4K box
Try retuning it from the Settings menu
Message 3 of 3
@Les-Gibson  You are a star! Thank you so much, all up and running now.
