Message 1 of 2
Lost subscription channels
I’ve lost access to my subscription channels this week, looks to be after the EE TV branding update.
software is up to date
tried a soft reset
anything else I can try before I need to call support?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Lost subscription channels
Have you restarted your router?
If you have, then the only thing left to try is a factory reset, which support might get you to do anyway and will delete your settings and recordings.
