Message 1 of 6
Main Menu Screen on my T4000
Triggered by the Blue 'Home' Button on the Remote - Has shrunk to a single line of Images and a Menu-Bar Line from which to select the EPG, APPs, MyTV Recordings etc down to SETTINGS  ...
Yesterday and for eons previous it had a line of Images for each of the items mentioned & you had to go to the top of the Screen for SEARCH & SETTINGs
Havent seen others commenting, so have I somehow 'shrunk' the Screen ?
Any ideas appreciated !
5 REPLIES 5
Message 2 of 6
Re: Main Menu Screen on my T4000
@speedtrip
Difficult to know, but it sounds like the UI has reverted to before the 2016 update. Mine hasn’t, so it’s not a general T4000 thing.
Soft reset the box by touching the On/Standby button for just over 8 seconds until it soft reboots, and see if that fixes it.
If not, then a Maintenance Mode, Keep Recordings, is a bit more thorough-going:-
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
Follow the instructions for Recordable 4K Box.
Please let us know if that fixes it!
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 6
Brilliant - would have been my next move, but wanted to check it wasnt something I'd done !
100% success - altho mind-numbing waiting for it to run the process - & finding an update too ... its the hiding of so many dross Channels that is so time consuming ...
Thanks for your diligence - wonder how many times you've had to paste in that info !
Message 4 of 6
@speedtrip I suspect that any changes to Home page layout that you have experienced are not down to anything that you have done but rather to Youview/EETV continuing to look to continue the journey  to improve the home screen.
Message 5 of 6
Dont think so - the Box had reverted to an old version - a Facory Reset has fixed & returned it to what i had previously .
Message 6 of 6
@speedtrip
It was enlivened by your 9-year time warp!
