Message 11 of 15
Re: Missing Freeview HD Channels
Hi @acecarver
  • Firstly if you plug your aerial  directly  into  your TV are you able using the TV's own tuner to receive  the Freeview  channels that you cannot get on your set top box.
Which Freeview  transmitter do you think you should be receiving your channels from ?
Message 12 of 15
if i plug the ariel directly into my sony tele and select TV instead of extension d-  HDMI,  all i get is snow on the screen and a number 11 in top right corner, i've looked for a channel tuning icon but there isn't one. TV is over 10 years old.
Message 13 of 15
the transmitter is at bruhsford, somerset
about 1/2 mile away as crow flies
Message 14 of 15
@acecarver
That sounds like analogue tuning. Does your TV do digital at all? Try a full retune and see what you get.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 15 of 15
an alternative approach
if your broadband is fast enough (22Mb or more)   then as your Freeview transmitter seems to be one of the Freeview Lite ones with a reduced number of channels then talking to BT and switching to the Box Pro and using  it in IP mode should give you more free to air channels (than Freeview Lite),
